Timeking's avatar
Timeking
time to replace brakes?
These are Dexter self-adjust that I have dragged 15,500 miles. At zero miles (i.e., new) the pads are 0.18 inch (9/32) and after 15,500 they are 0.08 inch (1/8). So I am figuring that the pads are losing 0.01 inch every 1550 miles. If you are supposed to replace the brakes at 0.04 inch (1/16), I only have 6200 more miles until worn.
I figure (My brain hurts!!) that if we are planning to go from Florida east coast to California and up to Canada, I need to go ahead and do this thankless job. I've done this before on previous trailer.
All that said, I wanted to see if I am figuring this right or not.
In advance
Thanks
  • Time,
    Ignoring the fact that your conversion to fractions sucks, brake pads are cheap. Labor is expensive on the road. A brake failure is even more expensive. Makes it a simple choice to me.
    Now, you measured a pad at 0.080? A 1/16 is 0.0625. That does not leave a lot of margin.
    Matt
  • A for effort with the micrometer brake lining measurements!
    F for decimal to fraction conversion.
    B+ for effort to micro manage your brake pad wear.
    D for efficiency. By the time you removed all the drums and micd the pads and reinstalled you spent more $ as a function of time invested than just replacing the $150 worth of overpriced brake pads would have cost you.
    And subjectively, you could lose a perfectly good half worn brake lining and have it chew up and spit out and just wish you hadn’t overthunk it.
  • Throw ALL those Math problems Into the trash can and stop over thinking.
    IF the brakes a low, AND your taking that multi thousand mile trip ( 6,000 - 10,000 ) , just replace them and be done with it..:S
    piece of mind = priceless
    and by the way... agree with the above .080 is 80 thousands where 1/8" is .125, or 125,000.... 45,000 thicker ( .045 ) than .080 now my brain hurts
  • You need to check your math.
    0.08 is much less than 1/8 of an inch. It’s less than 1/12 of an inch. 0.18 inch is also much less than 9/32 of an inch. It’s 9/50 of an inch. 0.04 inches is 1/25 of an inch.
    New, mine were 3/16 (0.185) inch and replacement is recommended at 1/16 (0.0625) inch.
Having RV issues? Connect with others who have been in your shoes.24,285 PostsLatest Activity: Jul 22, 2025
