eric1514
Jul 31, 2021Explorer
SoonDockin wrote:The NovaKool I put in my van was the R3100. 3.1 cu.ft. I only had 2 grp 31 AGM batteries (210Ah total) and 300 watts of solar. I would use between 40-50Ah/day and it was pretty easy to get that back with the solar or a drive to a trail head or the store. I put a digital thermostat on it set for 35.5 and it held that very nearly all the time. You should have no problem with all you envision for your RV.
I will confess, I never cared if I was off level when camping. Ya I get close but never bother blocking tires or running jacks down. I had a class C with a 7cu/ft dometic fridge that never gave me a bit of problems and I never tried to level that rig.
I had read that they needed to be level, but just assumed that was a "suggestion".
I spent this trip measuring every low storage spot to see just how many Ah I could fit. Seems like I can easily add 600Ah and only use up one storage hatch. I can probably fit 4-500 watts of solar on the roof, and my truck has the super duper alternator for charging on the road. We often camp in RV parks so charging batteries each night is easy. We like to go explore and on this trip visiting my kid in Colorado, we use it for everything. Probably ran the generator in places it was frowned on but when you need a microwave .....
The fridge is a big problem right now. It was hit and miss if it would cool, and clearly needs attention. As it does not use DC, I will be looking at the suggested retrofit options, and if necessary will replace it.
Thanks for all the support!
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
