Sfreiling's avatar
Sfreiling
Tioga Ranger 2010
Need help in figuring out the issue..first electronic mirrors in cab stop working, then back up camara (aftermarket install) stopped working, now the slides won't go out. Have check all the fuses we can find. Does anyone have a clue? Scheduled for appt but not till end of month.
  • ALso inside the BCC box there are 3 circuit breakers that can be reset by pushing a tiny round button on each one. Mine are grey, two are on the left side on the bottom.
    The other is on the top right. One goes to the DC distribution center, one goes to the converter and one goes to the levelers. If you call Fleetwood the will send you diagrams for your coach, free ! the electric and plumbing. Have your really long F.I.N ready
  • To use your slides your slides you should have your engine running and have your emergency brake on. Check to make sure you didn't kick the wire for it. Also fleetwood has a BCC box(battery contrl box) It has a lot of fuses inside . also has main,aux and charging relays. The cover comes right off. Mine is on the right under the hood. good luck. on edit the e brake was for levelers. senior moment.
    F 9 inside the BCC is for power window ,it may be for the mirrors
