sandeeAR's avatar
sandeeAR
Tips to keep water from freezing if possible
We have a Pirit Heated Water hose hooked up. Towels wrapped around faucet and water inlet connection at RV. When temperature drops below about 24, the water freezes coming out of the spigot on our kids house. Is there anything we can do to prevent this? Or do we just shut it off when it dips that low and use the tank. Sort of defeats the purpose of having a hose that works to 40 below lol. Thanks!
  • RoyB wrote:
    My house spigots all have the long value head where the value it actually some 12-inches or so away from the outside wall. Just leaving a water hose connected to this even with the spigot value closed under the house it still freezes here on the outside part at our house. I guess there is always standing water at this point if left connected up.
    Roy Ken
    I agree with Roy Ken in that the spigot will freeze. In fact this past spring I needed to replace one spigot that I had left the hose connected to as it had frozen between the handle and the actual shutoff point. Split the copper and had a leak in the spring whenever the faucet was turned on.
    Unless it is heated it is better to remove the hose and not just shut the valve off. You could get lucky as I did for many years or you could be replacing valves in very tight spaces.
  • Whatever electrical you use to keep the hose bib from icing up please read and understand the heat tape or blanket's instructions thoroughly. I used to cap the hose bib with a milk crate lined with aluminum foil and fiberglass blanket insulation.
  • K Charles wrote:
    Heat tape on the spigot.
    on the hose myself. campgrounds have had one on the spigot.
    bumpy
  • Sometimes keeping a little water running slowly can help ward off freezing.
  • RoyB's avatar
    RoyB
    Explorer II
    We always disconnect any external hoses when the temps get down to freezing...
    I always felt we was flirting with failure keeping them hooked up.
    Same thing always happens at camp grounds. Their water values are actually well below the ground but leaving a fresh water hose connected will freeze their connection point as well.
    Just me...
    Roy Ken
  • The hose is heated, but without a heat tape on the spigot it is going to freeze. Get a short tape and wrap the spigot and you should be fine.
Having RV issues? Connect with others who have been in your shoes.24,304 PostsLatest Activity: Aug 24, 2025
