profdant139's avatar
profdant139
Explorer II
Feb 26, 2019
Tire chains: ok to cut off extra links at end points?
I just got a new set of very heavy duty snow chains. I know I will probably never need them, but you have to carry chains in Calif. in the mountains, and there might be times when I am in the back country during a snow storm.
These are real chains, not cables. When I put them on in my driveway and tightened them up as much as I could, there were a couple of extra links at the end points, both inside the tire and outside. These are at the places where the hooks meet the other side of the chain.
I am a little concerned about these extra links flopping around and hitting my wheel well -- there is plenty of clearance, but it still looks like it could happen.
So I am asking experienced chain users -- is it ok to cut off some of that extra chain? Or should I leave it on, in case I need extra slack while installing the chain under difficult conditions? (I understand that once the chain is on, you roll a little bit and then take up as much slack as possible.)
Thanks in advance for your advice!
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
