JaxDad
Jul 04, 2018Explorer III
RJsfishin wrote:
A friend said his MH tires air up quicker when he unloads the weight.
The limiting factor in airing up tires, presuming he’s concerned with speed rules out hose size, is the difference between air supply and air already in the tire.
Air, like water or nearly anything, will flow faster from high pressure to low pressure than it will from high pressure to high pressure.
As for unloading first, as stated, nope, no difference. Think of it this way, you measure tire pressure with the rig up on jacks, no load, then lower it to the ground, loaded, then measure again. Did the pressure reading change with the ‘added load’? Nope.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
