mike-s
Jul 06, 2018Explorer II
JIMNLIN wrote:Maybe, with a cheap tire pressure gauge. But the pressure does increase as more load is added to a tire. Just not enough to matter. It's elementary physics.Old-Biscuit wrote:Y
Have your 'friend' check the air pressure in his MH tire...record it
Then have your 'friend' take the load off of that tire and re-check the air pressure
Hummmmmmmm?
Air pressure the same!
Yeah...I've taken many a ruined tire off a loaded trailer with 1750 lb up to 10000 lb trailer axles when I was on the road. Had the tire guy add the max sidewall psi to the tire. Drove back and mounted the tire on the loaded trailer...removed the jack and rechecked pressures. Always the same.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 27, 2026
