rlw999
Oct 16, 2020Explorer
I use a "Slime 40026 2X Heavy Duty Direct Drive Tire Inflator" pump that I found on sale for $60. The power cord is short, but the hose is long (it takes a really heavy power cord to carry enough current for a 12V pump, that's why it comes with a long hose).
I tried using a cheap cigarette lighter pump and ran into the same problem as you -- it could barely make it over 70psi, but I needed to get to 80psi.
If you get a 12V pump, get one with battery clamps, not a cigarette lighter adapter, the cigarette lighter can't put out much current, so those pumps don't have a lot of power.
If money is no object, ViAir has some great 12V pumps, but they are not cheap.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
