rhagfo
Oct 17, 2020Explorer III
wa8yxm wrote:
I have a Crafstman 120 volt pancake style (6 gallon) 150 PSI rated (160 actual) that does a great job on my 110 PSI tires.
It (with the help of a Harbor Freight 12 ton air/hydraulc jack-jack) can pick up the motor home for maintenance tasks.
Roger10378 wrote:
Most all of the major companies that make battery powered tools now have air compressors. If you have any of these tools you can buy the air compressor that goes with the other tools you have.
Just something to think about the pancake compressors require 120 volts to run, the ones that use the same batteries as your other battery tools may need to be recharged. My VIAIR on board runs off the trucks batteries, and best if engine is running. That and with the 2.5 gallon tank it will operate my impact wrench if needed for a stubborn lug.
One last thing it also runs my truck air horns.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
