CapriRacer
Aug 05, 2013Explorer II
pianotuna wrote:
Hi,
The RV was loaded (water tanks full), but only one passenger (me). There is little I can do to move weight to the passenger's side, unfortunately. The propane tank is on the passengers side. No other heavy items are on that side, and storage compartments are minimal on that side.
The Tires are 235/85R16 Toyo load rating E. Before I had 225/75R16 so I'm pretty certain I was overloaded.
Wow, you certainly were overloaded before.
Based on what you have posted, I think you need to use 80 psi in the rear and 65 psi in the front. If I remember correctly, that was what the vehicle tire placard said for the smaller tire - correct?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
