jadatis
Aug 05, 2013Explorer
pianotuna wrote:
Hi Jadatis,
Your post is too complex for me to understand. The Toyo tires do have the same rating as the Michelin and Goodyear tires (3042/2778).jadatis wrote:
Filled only the loads, into my MotorhomeRVtirepressurecalculator and here a picture of it, and chanched it already because I saw the tires in a next post. Looked in a list of Goodyear to find 3042/2778lbs as maxload and 80 psi for E-load. Toyo would not load, but is 99% sertain same loads.
That is because I first made the post without the tire-data, and later chached it because I found them in your later post.
This makes the sentenses sowewhat confusing I realise.
But now you convermed the tire data You can yust read the picture.
But search for the GAWR's and GVWR, and fill them in in the spreadsheet , and it gives more info.
Or is it that you dont understand the other things.
Then only remember the advices of 55psi front and 86 psi rear and dont mind that rear is 6psi higher then AT pressure of 80 psi, 10psi over that is allowed by TRA.
But you weighed without co-driver and other persons in it
passenger side gets heaviër when co-driver is in it, so gives less worse and also weightdivision Front/Back gets a bit better.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
