jadatis
Aug 05, 2013Explorer
pianotuna wrote:
Hi Capri,
Yes, I definitely was exceeding the capacity especially on the driver's rear, with the OEM tires.
Yes, the vehicle placard says 65 front and 80 rear.
Someone suggested in another thread that the inner duals might be put at 2 pounds lower--i.e. 80-78-78-80. Is this a good idea?
I will move the generator as far to the passenger's side as I can.CapriRacer wrote:
Wow, you certainly were overloaded before.
Based on what you have posted, I think you need to use 80 psi in the rear and 65 psi in the front. If I remember correctly, that was what the vehicle tire placard said for the smaller tire - correct?
If your generator is placed behind the rear-axle it yust gives less weight on the passenger front side, strange but true.
So this only would have effect ,if generator is between the axles placed.
But if with your old tires there was overloading, then for the GAWR rear there is still overloading, not for the tires anymore. The old tires must support the GAWR bij law so GAWR rear is below or less then 4 times maximum load of old tires.
But also overloading axles is forbidden by law.
I dont mind but if you are weighed, and it proved to be over 10% you would have to unload in Holland and get a penalty.
Chanche on that is practically zero I know ,but also the technical maximum axle weight rear gets overloaded at a sertain weight, and then laws of nature punisch with unintended camber angle wich needs even higher pressure.
EDIT: Filling this in my spreadsheet I discover a little failure , it gives the reserve weight with 10 digits behind the point , have to round it , but not a real problem.
But if you can procuce the GAWR's the picture gets more complete.
You are around the GVWR so with passenger and some more load yust a little overloaded, but your GAWR rear probably overloaded, wich is also forbidden.
already answered about the genearator in this crossing post.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
