LarryJM
Aug 05, 2013Explorer II
pianotuna wrote:
Hi all,
I finally got to the scales! Here are the numbers. I'm looking for recommendations on tire pressures.
front 1600 kg 3527.396 pounds
rear. 4890 kg 10780.6 pounds
Total 6490 kg 14308 pounds
Driver's Front 910 kg 2006.21 pounds
Driver's Rear 2510 kg 5533.603 pounds
Passenger's Front 780 kg 1719.61 pounds
Passenger's Rear 2350 kg 5180.863 pounds
55 to 60 in the front and 80 in the rear and realize you are right at the tire max load limits on the rear tires (2778 per tire or 5556 per side). I would look to take a couple or hundred lbs. off the load on the rear tires. If those wts. were with empty tanks having much water onboard could well overload those rear tires. I also sure wouldn't be traveling at much above 60 to 65 with those wts. on those rear tires.
Larry
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
