wing_zealot wrote:
It won’t have one, They weren’t required in 1999.
Sort of, the yellow tire sticker did not exist before 2005, but before that sticker there was a VIN sticker which had not only the VIN but other things like weights, tire sizes and might have even had recommended pressure for the tire sizes.. Mine has been gone before I bought my TT but I have seen them before.
However, with trailers unlike automobile tires, the tire size and capacity is often right on the edge of not enough capacity. Because of that, the general rule is to inflate trailer tires to the max sidewall pressure. That pressure gives the tires the absolute maximum weight carrying capacity rating for the load range.
The VIN sticker was typically applied on the drivers side of the trailer on the siding near the front of the trailer box. Sometimes applied on the front driver side of the trailer box and sometimes applied to the drivers side of the trailer tongue..
Notice a theme?
If yours is still there it will be on the drivers side of the trailer somewhere near the front..
But, if all else fails, read the tire sidewall and air up to the max sidewall pressure (cold temp of course). Do not adjust pressure when hot (after driven for more than a couple of miles).
