Most RV's will have the tire size and recommended psi on the VIN sticker or close to it. But its better to use a load chart.
One safe way of choosing an air pressure is to reference a load chart for your tire size and choose the pressure that covers your GVWR. Even better is to know your actual axle weights and adjust using a load chart.
Most stickers on trailers I've seen just use the tires max pressure rating and the centers wear out first if you do enough miles.
Motorhomes usually have an actual calculated number based on the tire size and GVWR just like your car or truck does.
I'm using E rated ST tires instead of the usual D rated my trailer came with. Thats what most shops around here are stocking. So, I'm not running 80 psi in mine like the sidewall max says. I rather use a load chart!
