jadatis
Mar 01, 2015Explorer
Probably the load is a bit more then 3700 lbs .
Part of the load is carried by the constuction of the tire.
I state that , but discussable to about 100 lbs a tire.
So most likely the real load is about 3800 lbs .
And also inacuracy of determination of surface on ground plays a part.
You could test it by weighing per wheel .
Also you can put for instance 30 psi on tire and then determine the surface again , then probably lower then 3700 outcome because of more deflection so more load carried by the construction of tire.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
