IAMICHABOD
Aug 28, 2017Explorer III
What is needed is a extended valve stem that will let you quickly check your tire pressure.
Braided Extenders have a very bad habit of leaking and coming loose from the attaching points whipping around tearing out the valve stem and causing catastrophic tire loss. I have experienced this.
The best on the market,that are the original,are Tire Man.
Chuck is the original designer of these an he has been around for years. If you have any questions just give him a call, he is always happy to help. Any others are just cheap reproductions of the original.
The kit looks like This it is for all 6 wheels,they also come with flow-thru valve caps so you don't even need to take then off to check the pressure.
Here is a list of all the products he sells.
They are compatible with all Tire monitor systems.
