anon125's avatar
anon125
tire valve extension adventures
we went to a garage to have the tire pressures check as the MH has not been used in years.
the assigned technician was a young kid who clearly was new at this.
then we drove 50 miles to the polishing place.
there they polished the whole MH including the wheels- probably with a power tool.
we drove back. everything seemed to be okay.
a few days later we visited the MH and the 2 outer tires were completely flat.
the inner and outer tires have extensions. the inners are flexible.
the outers are little solid pipes in a V or L shape.
they were completely loose.
a kind local sorted all that out.
he tightened the valve things by hand.
i have heard of a tool to tighten them, the local tire store called it a valve extention wrench.
cannot find one. do they exist?
our puny fingers could never tighten those nuts!
do these things usually stay tight? the MH now has 16000 miles and they were never loose before.
i thought of getting those things that send a radio signal to say the tire pressure but i thing they would shake to pieces on the end of those long flexible extentions!
thanks all
  • thanks
    the MH only has to do 4000 miles before we quit. hope they are not expensive!
  • harley-dave wrote:
    I had problems with them coming loose also, so I replaced all my extensions with solid one piece long valves from Borg. Our tire shop carries them, check yours. Stopped the leaking and extender coming loose problem completely.
    Dave
    Me too. Very easy to check and add air.
    Look for DuallyValves at the site above.
  • I had problems with them coming loose also, so I replaced all my extensions with solid one piece long valves from Borg. Our tire shop carries them, check yours. Stopped the leaking and extender coming loose problem completely.
    Dave
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
