Gdetrailer
Aug 18, 2022Explorer III
80 PSI tires, that still could be considered normal.
My flatbed trailer spare was down to 30 PSI after not checking it for several yrs. Splashed soapy water all over it, found no leaks. Aired it up and called it good..
Tires should be checked much more often that two yrs..
Heck, I have some new tires with innertubes for a 120 yr old car that take 60 PSI, those lose 4-5 PSI every month..
I would have just aired up and checked them in a week or two instead of just replacing.
You have a good chance that there was nothing wrong with the tires or could have had some dirt/rust on the seat of the rim or valve core or stem leak and replacing the tires solved the rim or valve stem issue..
When in doubt, pull the tire, run some soapy water around front and back beads and don't forget valve stem. If that fails to get bubbles then carefully check and inspect the treads for embedded nails, bolts and other road junk.. Nails, screws and small bolts can embed just enough to create a slow leak and can be often repaired.
I realize it is easier to just pull up to the tire shop and have them swap tires, but for 2-3 yr old tires, seems to be a bit wasteful approach.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
