valhalla360
Aug 18, 2022Navigator
joebedford wrote:
4 tires were down 15psi to 65psi; the other two were down 50psi to 30psi (over 2 years)
You are talking about the difference between losing 0.021 PSI per day vs 0.068 PSI per day.
It's losing air at such a slow rate, that very minor variations in where the air is escaping, could explain the variation. Basically, you have magnified the static in the data.
If you were using them and checking them once a month, they would be within 1 PSI and most analog tire pressure gauges won't show that level of accuracy.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
