Popsie
Sep 27, 2013Explorer
Boddhisattvha wrote:I have a different brand of heaters, but the way mine work is that the control board gets a signal from the thermostat, turns on the fan, (and if the fan switch senses enough air movement), turns on the igniter, and then turns on the propane. Of course, since you have a different product yours may work differently. I've had to replace the blower motors on both of my heaters because the bearings wore out and they wouldn't blow adequately.
When I had the faceplate off I did not see anything like what that describes but that doesn't mean there isn't one. But if the sail switch wasn't working wouldn't that mean the igniter wouldn't spark? Since it cuts off the electric end and not the propane end?
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 18, 2026
