newman_fulltime
Jun 15, 2018Explorer II
dougrainer wrote:
As Newman stated, there is no relation between the Toilet water and the Water Heater water. EVEN if you had hot water to the toilet input, the hot water increase pressure(VERY SMALL) would not leak out at the Toilet base. You have a HOT water leak that is caused by the small increase in water pressure, probably at the EXIT HOT fitting of the water heater. The HOT water is causing the line bevel washer to leak from the HOT of the fitting. Can you get access to the back of the water heater? Doug
Or when it gets hot the weld at the anoide rod threads expands it leaks when it cools off leak stops
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
