j-d
Jun 15, 2018Explorer II
gbopp wrote:
You may want to check the water lines and make sure hot water isn't going to the toilet.
Easiest way would be to turn the water heater on, let it get up to temperature, then flush the toilet long enough to see if the water flushing it is hot.
But hot or cold, toilet flush valve still shouldn't leak...
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
