cm2785's avatar
cm2785
Toilet pipe
Hi guys, I have a 1996 Bounder 34j and I notice that the pipe from the toilet has a slight angle before going into the tank. No matter how much water it seems toilet paper starts to cause a backup there.. do they make anything that is flexible that I can put down there to clear the clog? Thanks!
  • maillemaker wrote:
    Last time I posted this comment it got deleted even though I'm using words appropriate for 3-year-olds.
    Steve
    Poo is copywriten for Winnie, try kaka or merde. Hard to guess without any guidance :)
    To the OP try using a bidet instead of paper ;) Don't smear it, wash it.
  • Also, one thing that I learned is that the bowl has two flappers. One just releases water, the other opens the valve and releases water.
    If before you poo you fill the bowl with water first, there is more water to help everything go down.
    Steve
  • I had that problem...got a 4 ft length of (flexible) 1/4 inch plastic pipe and use that for any clogs.
    Actually, flush often (just not at the finish) and use as little paper as possible.
