westend
Dec 18, 2013Explorer
Over at the Wind-Sun Forums they almost launched a posse after me when I told them I was going to drill the frame in different places than the original locations. All kinds of doom and troubles were forecast. Of course, I went ahead and drilled. I have added aluminum angle pieces along he sides of the original frame.
An easy recovery from a misplaced hole is to fill it with bolt and nut. It should make it stronger in that location.
I used three aluminum channels to support the tilt struts, you probably don't have the luxury of that material in Mexico. Using a full length piece of material will be stronger than just drilling a mount bracket into the roof, though. The torque of the wind affected module will be spread along the length of the strut bracket.
Tilting mechanism:
Detail of mounting bracket, strut, and angle piece in stored position (panel laying flat, upside down in this construction phase):
Hinges installed to enable tilting in perpendicular axis:
Back side of hinge attachments:
Tilting mechanism:
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
