Almot
Dec 21, 2013Explorer III
I think Mexicowanderer is 200 miles away, it's a big country. There is plenty to drink in a local village though.
My work is still in process, but some pics won't hurt. Not as elegant as your design, but hopefully will be strong. Poor quality of a flip-phone camera, sorry.
Lower-South bracket - parallel to the back of the trailer.
6 screws #10, all in 3/8" particle board, not in rafters. Could have been 5 screws, since it's a lower side. The rafter is right under the panel frame, but it had a lot of screws already, holding the plywood to rafters. So I flipped the bracket away from the panel and drove the screws into plywood alone.
Upper-North bracket with mock-up wooden tilt leg - and the reason why I needed heavy bracketage.
See 2 vents under the panel - they are 3" high, so I needed 4" brackets to clear the vents when the panel is lowered flat. There is no 4x4" angle in 3/16" or 1/8" thickness, so I had to use 1/4". 3 screws in the rafter and 3 in the plywood. This was my very 1st bracket and I overdid it, 2 screws in rafters + 3 in ply would be enough. Sealed and painted, it will outlast the rest of the trailer.
Short pirate leg is for now, until I get 2ft long 1/8" thick aluminum angle. The panel top is skewed for now, to squeeze thick wooden leg in. With all the screws tightened there would be 1/8" clearance in vertical plane between the wall of the bracket and side of the panel, just enough for aluminum angle-strut.
Both the lower and the lifted corner of panel have nut inserts where 1/4" machine screws go in.
OK, enough work, merry Christmas to everybody.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
