westend
Dec 21, 2013Explorer
Ya, that crack about the tipping was just that, knew you were making progress :B
Those brackets will be more than enough to hold the module but more brings peace of mind.
Do you have your angles worked out for the tilt? Here's some good copy on different methods of tilting. I have the Hilton parked in the Winter so just use the maximum angle, fixed. I thought it also might keep the snow off but I see 3/4 of the panel is blocked, today. I know the cure for that.......drive South. :W
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
