wa8yxm
Jun 28, 2015Explorer III
What happened to the Carrir Air C? (Top unit or control unit failure)
Two companies make replacement top units that with the aid of a simple adapt-a-kit (Which they also sell) will replace the Carrier Rooftop unit.
I went with Advent Air.. Suggest you do not
I think Coleman is the other one (not sure)
But with this type of replacement you use the same remote.. The same ducting uint, The same lower unit.. From inside it is same-same-same-same.
Only the part on top changes.
You may have to change one of the connectors (IF so a new one is included in the adapt-a-kit) this requird my skills as the RV technician who did mine had no clue as to how to install the thing..... I'm certified on just that,, so it was no problem.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
