vandave
Jun 14, 2018Explorer
Torque size
Can someone please tell me what size torque fits the oil change access on the on an 4000 generator. Thanks. None of mine seem to fit.
Chum lee wrote:vandave wrote:
...and the nut is 12mm. I put TORX and mm size with a permanent marker on the small access plate for this fall.
I just talked about this exact issue in another thread. I suggest you trash can the torx screws and replace them with metric hex head cap screws. (unless you're worried about someone (a terrorist maybe) tampering with the oil drain plug on your genny.
Chum lee
