1ed's avatar
1ed
Torque Wrench Where to buy/rent
Just purchase new trailer and got the Reese Steadi Flex System and now I at home I need to adjust the ball height and the nuts need to be torqued to 340lbs. I only have a 150 torque wench and I have made numerous calls around to see if anyone rents this large of a torque wrench and the answer is no. I have called all the auto parts stores, home improvement stores and the local tool rental place with no luck. I really do not want to spend around $300 bucks for a tool that I will only use occasionally. Any ideas and yes I am CHEAP CHARLIE HA HA. I am 80 miles away from any dealer and 45 miles from any auto garages.
  • Another possibility is a trailer hitch installation shop or even a U Haul shop.
  • Around here the auto parts store have loaner tools but I am not sure it would be that big. Might check though.
  • Dick_B wrote:
    If I'm remembering correctly one can pull 1/2 his weight based on the friction of you standing on the ground. So if you weigh 200 lbs you can pull 100 lbs. If you use a 3 1/2 ft. cheater bar you will come close to the 340 you are looking for by pulling as hard as you can.
    If you brace your foot against something all bets are off.
    So I guess the OP merely needs to start eating. When he gets to 780 lbs body weight, he's all set, no torque wrench needed.
  • If I'm remembering correctly one can pull 1/2 his weight based on the friction of you standing on the ground. So if you weigh 200 lbs you can pull 100 lbs. If you use a 3 1/2 ft. cheater bar you will come close to the 340 you are looking for by pulling as hard as you can.
  • Get a cheater bar and stand on it at the right weight/length to create 340.
    May need 3/4" or 1" drive.
  • Put them on tight, then the next time you go by a truck tire shop, pull in and set them up.
  • What you need is a torque multiplier. I don't know if any place rents them and they aren't cheap but they're cheaper than a torque wrench that will do 350 foot pounds.
Having RV issues? Connect with others who have been in your shoes.24,243 PostsLatest Activity: May 11, 2025
