JiminDenver's avatar
JiminDenver
Explorer II
Jun 19, 2015
Torture test of the solar A/C
I titled it that because it wasn't intended to be used this way but it could happen I guess. To start with I don't get good sun here until after 10 am but the trailer does in the lot all buttoned up. It was all ready in the 80's by the time I got it home, the system set out and the A/C installed.
The things that worked against it was the heat was rising so the best I could do was close it up and let the A/C run. I set a digital thermometer mid trailer and after a hour it dropped a degree even though it was in the high 80s outside. I tried to reduce heat load at the ceiling but opening the vents just let the hot air trapped under the max airs in. I ended up putting the foam insert into the front one and closng off the bathroom to reduce the area to be cooled. I also blocked off the bunk above the A/C because without air flow it was a oven exposed to the sun.
After a hour the temp was holding at 81.5F in the trailer. It would dip below 81F but every time I opened the door it added to the heat load. I would open it to check on the battery voltage and controller output evry hour or so. The 8-D was holding above 13v and the amps out were in the mid 40's.
After 3 hours it got up to 95 and the temp inside went up to 82.+F and now after four hours with three of them between 92 and 95F the trailer is 82.9F and the battery is at 12.9v under load. Not bad considering it was resting at 12.4v this morning. The panels are flat so peak sun has passed.
So does it turn the trailer into a ice box in this heat? No. Does being out in 95F heat and stepping into a trailer at 82F feel good/ Yes
The system is suppose to keep us cooler up at elevation where it is 82 degrees right now. Normally we would have done things to keep the heat load from building before mid day and the A/C would have stood a chance at lower temperatures to start with. Even the load on the system would be less because at lower temperatures the compressor will cycle which it hasn't all day.
I may run the test again tomorrow but with the A/C in the bedroom window where the cold air can be directed up to the ceiling. I'll let it keep going tonight until the 8-D and solar get down closer to 12v and them put a charger on it. It cools quicker up there than here, so running it till 6 PM would work.
At 2 PM and 95F outside
  • The panels are 250w each, the A/C is a Frigidaire 5000 BTU energy star window unit that pulls 450w once the pressure is up.
    I shut it down at 5 pm since the trailer was going to shade the panels. The 8-D bounced back up to 12.9v and the panels will get a few minutes to work on it after the trailer was moved.
  • The humidity is 15% right now Mex
    Roy
    Had I parked the trailer in the shade it would have been a lot different. We rarely have shade up there so I wanted it to be realistic. That is also why the panels are flat as they will be installed, not tracking. I could have started the system at 8 am and run it until well after 6 pm if I were tracking.
    Interesting note. Sitting in the trailer with the little A/C humming away doesn't sound much different than it does when the generator is running and the roof A/C is on. Outside of course there is a big difference.
  • RoyB's avatar
    RoyB
    Explorer II
    Too bad you can't put up one of those portable carport TENTs for RV's shade... They are just aluminum frames and tarps...
    The local swimming pool here uses them for the picnic tables during the season... They can't cost all that much.
    Of course that would require solar panels on the ground I guess...
    Roy Ken
