wa8yxm
Sep 18, 2022Explorer III
The metal part engages a paul at the bottom of the spring assembly. I'd guess it's not properly aligned. also the spring assemble needs to mate with the shaft. Fairly easy to do but you may need to be able to see it.
Final issue. .The plastic shaft they put in oem likes to break. The brass one they replace it with much better. (The shaft that goes into the ball)
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
