anon125's avatar
anon125
tow bar UNinstallation
in 2006 when we got the tow bar thingy on our 1997 CRV installed we went to the professionals.
now the honda dealer says they would like to replace the 20 year old oil pan gasket cos there is a trace of oil on the garage floor. and the pan is oily.
do we let the honda dealer remove the tow bits under the car and replace them or go to a tow bar installation people?
thanks
that middle picture. anyone familiar with the underside of 97-2001 CRVs?
  • It is about time that poor ole car started marking its territory.
    It would be cat litter for me also for just a smidgen of oil.
  • It ain't rocket science. Anyone that turns wrenches for a living should be able to handle it.
  • Those photos tell Me two things.
    First is obvious ,next Oil change replace the Drain Plug seal !
    Next time You are in the Car Wash ,or if You have a Access to a pressure washer and some a Purple Degreaser , spray down the Engine!
    Most of that oily mess is coming from the top . Likely a sloppy Oil change or spill when adding oil.
    After you clean it up check periodically to see if there really is a leak!
    Just My 2 cents worth !
  • My solution to some minor seepage on a 20 year old vehicle would be a little cat litter on the garage floor.
  • I didn't see anything that looks like the base plate would restrict the removal of the oil pan. As far as the drip from the oil pan, maybe just a new oil pan drain plug gasket is needed.
    Ron
  • What you can think about dealer who can't handle tow bar?
    I always advise to let single person to do whole job as when you get 2 different contractors and something goes wrong - the finger pointing always start and you are in deep do-do.
  • j-d's avatar
    j-d
    Explorer II
    At the age of the vehicle, I think the issue to watch for is being very careful of plastic parts and related fasteners. They've had a lot of time to get brittle.
    I don't see why the Honda shop couldn't remove the base plate or enough of it, to gain access to the oil pan. Another alternative could be a body shop, or a place that does trailer hitches. Since you didn't install it yourself a dozen years ago, I take it you don't want to work on it now...
