landyacht318
Nov 04, 2019Explorer
CJM1973 wrote:
If my DC to DC charger is rated at 40 amps (Renogy has one), would it be a bit taxing on the 150 amp OEM alternator? Any benefit to upgrading to a 220 amp alternator in this case?
Secondly, do these dc to DC chargers act just like a conventional onboard RV multiphase converter? Bulk to absorption to float? From my understanding, with this setup, I would rarely get above 80% stage of charge after a 3 hour drive, right?
How taxing it would be to the alternator would depend on how long your depleted batteries could suck up 40 amps, and how much other loads the alternator is having to power, like headlamps@~15 amps, blower motor on high @~18 amps, ect.
My 1989 engine at 2k rpm requires 12.2 amps to run ignition and fuel pump, not including field current to alternator. Other vehicles will vary.
Heating of the alternator is the issue, and how hot it gets depends a large amount on the vehicle's engine bay, and the speed one is travelling. I can max mine out at 120ish amps@ 65mph and the stator does not exceed 138f, but idling parked at 50 amps max and it shoots upto 220f in a few minutes.
An alternator with a bigger rating 'should' be able to handle or exhaust the heat better.
I have no experience with the DC to DC chargers sold as such, but I do believe they take whatever vehicle voltage is allowed by the vehicles voltage regulator and try to do 3 stage battery charging stepping it both up and then down once it has decided to 'float' them.
I'd not want to be limited to the Renogy 40 amp max, but I have an externally regulated alternator and use a modified voltage regulator so I spin a dial to choose a voltage and watch voltmeter and ammeter respond accordingly.I had to trick my engine computer in order to do this without setting off the check engine light, but it has been a great reliable modification.
I do make use of Dc to DC voltage boost, and voltage buck devices, but I have not tried to add one to a 7 pin trailer harness. I did buy a '1800' watt voltage booster to experiment with, but it was so poorly soldered and things went pop, and smoked a wattmeter rated upto 60 volts when I had it set to 24v with little load, then changed the load.
I have a 150 watt voltage booster that works well considering it was sub 3$, there are 300 400 and 600 watt ones sold too.
I've used this booster to equalize one battery at 16.2v from another at 12v which had a regular charger on it. Some of these have current limiting potentiometers so you could limit it to ~15 amps to save the 7 pin wiring harness.
Some have done the inverter on engine battery, powering a high amp charger in the trailer, over a quality 120vac extension cord, in your situation. If the inverter can draw more than the alternator can make then it feeds off the engine battery when charging the depleted trailer batteries at a high rate. In this case a larger engine battery gives more of a cushion when rpms are low or one forgets to turn off inverter when parked. One needs to keep in mind engine starting batteries do not appreciate being cycled, and perhaps employ a marine battery instead when one is due for a new engine starting battery.
There's lots of ways to get more juice from alternator to depleted trailer batteries, and no 'one' single correct way, no matter how loudly the opinion is typed.
-Fat copper to trailer batteries and whatever voltage is allowed by vehicle, is what it is.
Dc to DC chargers, over adequate cabling.
Inverter on engine battery to feed charger on trailer battery over a good ac extension cord
a simple dc voltage booster on the 7 pin wire.
All are valid ways, and the choice can be influenced by what voltage the vehicle allows when the alternator is hot.
The big enemy is voltage drop, as depleted batteries only getting 13.6v at their battery terminals will be accepting 1/3 to 1/2 that they would had 14.7v been reaching the terminals.
I get a lot of bile about this 1/2 to 1/3 cobservation, but I have ammeters and voltmeters on my dash next to my voltage control dial, so this is actual repeatable observation and the main variable over the last 4 years has been the battery condition, 1/3 when newer, now closer to 1/2.
When disbelievers call me out its like one is travelling 60mph, as indicated by a radar sign, highway milemarkers and a clock, and ones own speedometer, but someone else is saying you are only doing 48mph based on their beliefs alone.
1/2 to 1/3 the amp flow is real data, when 13.6v reaches the terminals compared to 14.7v. Other batteries might vary some, but not a lot.
as far as how much charging you can get done driving in x amount of time, it is all dependent on how low your batteries were when you started charging/driving, and how many amps you can feed them and this is dependent on the voltage reaching their battery terminals.
regardless, it basically is impossible to recharge lead acid from 80% to 100% charged in less than 3.5 hours assuming ideal voltages reaching battery terminals, But 2.5 hours at ideal charge voltages in the mid 14's can at least get one in the 97% state of charge range, where 13.6v might get one from 80% to 84% in the same amount of time.
The more aged the batteries the longer the 80% to 100% takes, especially at lower charging voltages.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
