troubledwaters
Aug 06, 2018Nomad
I don't understand, if you got 12V on the truck side, you are charging the battery. I didn't look up what pin should be hot so I presume you got that part covered. As far as charging the battery is concerned, how fast it charges depends on how many amps your alternator is producing and how many amps are not already being used by the vehicle.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
