theoldwizard1
Aug 06, 2018Explorer II
Derick wrote:
I get 12V at the 2 oclock pole on the 7 pin connector on the truck. Also, I get 12V at the corresponding pole on the trailer side, presumably from the camper battery back feeding it.
One more step !
Turn off all 12V load in the trailer. Disconnect the trailer battery and see if what voltage you are get AT THE BATTERY CONNECTION With the engine running a high idle. I will bet it is less than 13.5V.
Read this on DC-DC battery charging.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
