theoldwizard1
Nov 12, 2017Explorer II
MEXICOWANDERER wrote:
https://www.ebay.com/itm/DC-DC-Converter-10-12-15-20A-150-250-300-400-1200W-Step-up-Step-down-Buck-Boost/382219150784?hash=item58fe0965c0:m:mCHY1nLxgu47cYpdyd1LmDA
These critters boost voltage up. Way up. Send sixty volts through long long circuit
Then at the batteries, another type unit (same ad look down the list) will BUCK voltage down to whatever you set the potentiometer to.
Here is a 55 volt max input voltage solar controller to sixty amperes capacity. Smart charging.
https://www.ebay.com/itm/NEW-20A-30A-60A-PMW-Solar-Panel-Charge-12V-24V-LCD-Battery-Regulator-Controller/132046821183?hash=item1ebe9a973f:m:mSp7lk-3EMgMQhbOaaXObyA
You have the formula ! (Not sure about the durability of that cheap Chinese solar charge controller.)
Wheeeeee... your alternator becomes a SMART alternator (whoopee)
