MEXICOWANDERER's avatar
Nov 12, 2017
Towed Vehicle Battery Charging Interesting Idea
https://www.ebay.com/itm/DC-DC-Converter-10-12-15-20A-150-250-300-400-1200W-Step-up-Step-down-Buck-Boost/382219150784?hash=item58fe0965c0:m:mCHY1nLxgu47cYpdyd1LmDA
Send sixty volts through long long circuit
Units can be paralleled (this I like a lot). HIGH AMPERAGE POTENTIAL
Adjustable voltage regardless of Laurel & Hardy grade chassis engine ECU schizophrenia. Means YOU select what your rig's batteries need right at the batteries.
  • I had mentioned something like this a long time a go ! Just be careful because those heat sinks are way undersized and require good air flow (fan) to prevent them from melting down.
  • Just affix a wind turbine / generator to the roof of the toad and be done with it....
    Take advantage of some of the parasitic wind loss the tow vehicle produces.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
