1L243's avatar
1L243
Explorer II
Jul 09, 2022
Towing With Air Bags.
I was curious on what kind of air pressure your running in your airbags?
I have a 1999 2WD 7.3 F250. I tow a 10,000 pound bumper pull Toy Hauler with 1220 pounds of tongue weight. I use a 15,000/1500 pound WDH
I have had my air bags on for several years and with 5 different trailers. It's hit and miss on the right air pressure. Typically I have ran 35 psi. But recently I experimented with 60psi and I have to say the truck felt much better. I have Air Lift bags which go up to 100psi.
At 60psi my truck is more level. I tend to get a 2 inch squat after connecting the WDH and running 35psi.
Anyway chime in if you run air bags I would be interested to hear what your running.
  • ^What he said!
    You still need to load the suspension a fair amount. In your scenario, either you’re waaay off in the amount of weight you think you have on the truck, or it’s riding completely on air and neither your springs nor the wdh are doing much of anything.
  • As mentioned there psi does not mean squat!!! Air only enough to get your tow vehicle to set "LEVEL"
  • My air bags are 10 to 15 pounds without my TT or a load and 60 to 65 with…but that’s me and my rig. Not you. I’m absolutely level with my TT and truck at 60 to 65 pounds. You must coordinate air bags with hitch height for ride and leveling however.
  • What another person runs is irrelevant to your setup, as it’s not likely the same.
    That said, I run about 40psi, no wdh on a coil spring Ram with about 1500lbs tongue weight toyhauler.
    Honestly, I can’t imagine running as much air as you do with that truck and a wdh, unless your springs are shot or your tongue weight is heavier.
  • I put Air Lift 5,000# bags on my 24' Class C when I started towing my 6 X 10' {8' tall} cargo trailer. I typically haul either my Can Am Spyder or my Polaris Rzr SXS with the loaded trailer coming in between 2,200 - 2,600# depending on what additional toys I load {my coach with the 6.8L V-10 us rated to tow 5,000#} so I am nowhere near my theoretical limits.
    The whole purpose of the air bags is to ensure that the loaded/hitched trailer tongue is dead level with the ball exactly 16" from the ground to the top of the ball as per the trailer manufacturer's recommendation. For me that requires 50 psi in the air bags. I keep 25 psi in the bags when not towing per Air Lift's recommendation to prolong the life of the bags as they do not do well when completely deflated. The bags will take up to 100psi but I would never have enough of a load to warrant that much pressure.
    At a full load and 50 psi the coach rides and handles just fine "almost" like the trailer is not even back there. The coach has always had great ride and handling characteristics and I was surprised that when not towing running the 25 psi dramatically improved the ride overall which I was not expecting, but do love... go figure. :h
    Here is a short of the rig:
    :C
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
