RJsfishin
Sep 30, 2015Explorer
Greased bearings w/ a preload are too tight. Some bearings that run in oil, do call for a preload. If too tight, there is no room left for grease, and they will run warmer.
Bearings w/ any roughness or pitted will also run warmer.
Wheels should run freely, w/ little to no play would be correct.
Seals, no biggie, as long as they press into the wheel, and they push onto the "seal surface" w/ some resistence.
Jack up each wheel, spin it, you should be able to tell the problem by comparison
