TakingThe5th
Sep 30, 2015Explorer
X2. A little trick I learned about tightening the spindle nut was to try moving the washer behind the nut with a screwdriver, gently of course. If it won't move - too tight. If it moves too easy - too loose. Be sure to rotate the wheel as you tighten it up to make sure everything is seated correctly. Then back off as necessary to find a hole for the cotter pin.
