Bill_T
Sep 30, 2015Explorer
Do you have access to a bearing supply house? If so you can find quality seals and bearings there. We have Industrial Technologies in my area. I've always had good service with Timken bearings/races and Chicago Rawhide seals. Give the people there the numbers off your parts and they can cross reference to a better grade part if that is what you would like to do.
I also subscribe to the looser is better than tighter method. Tighten the castle nut as tight as you can get it with a 12" adjustable wrench, then loosen the nut, then retighten by hand until the nut touches the bearing and insert the cotter pin in the closes hole.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 19, 2026
