NinerBikes
Sep 30, 2015Explorer
TakingThe5th wrote:
X2. A little trick I learned about tightening the spindle nut was to try moving the washer behind the nut with a screwdriver, gently of course. If it won't move - too tight. If it moves too easy - too loose. Be sure to rotate the wheel as you tighten it up to make sure everything is seated correctly. Then back off as necessary to find a hole for the cotter pin.
This/\ Tension is correct if you can move the washer with a little bit of resistance under the set nut, with a screwdriver pushing the washer side to side.
