dryfly's avatar
dryfly
trailer brake problem
Recently installed 4 new electric brake assemblies and Prodigy P3 controller. Worked great for 800 miles.
Plugged the trailer in one morning and got a "Short" error on the controller. Checked all truck/trailer wiring and nothing evident. Next time I plugged in trailer I got an "Overload" error. Prodigy tech support this does not indicate a short to ground but that the system is drawing too much current.
This has evolved into a highly intermittent issue with the brakes working about half the time and getting the "Overload" the other half. I have eliminated the truck and controller as being part of the problem.
Obviously it has to be wiring in trailer or brake magnets causing the problem. The error will not occur with the truck setting still, but it just doesn't react like a wiring issue, and should show up as a "short" error if it was wiring.
Is it possible that the magnets could be breaking down internally under load of breaking??
  • Crabbypatty wrote:
    As I learned even though the P3 is indicating a short, you still have brakes its just that one of the magnets, or wiring to it has an issue.
    What an OP suggested to me and I did was jack up one wheel at a time and spin it, then have someone depress the brake, to locate the wheel. Once that is done and you find the wheel, check the wiring, looking for loose, worn rubbed. You can do a continuity check by connecting both sides to an ohm meter. I bought 50' roll of two conductor 16 gauge wire from the home center (lamp cord) and soldered on alligator clips. I stuck it in the appropriate hole on the 7 way plug then back to the wheel.
    In my case the wires were fine, trailer ground was fine, and it turned out to be the magnet. The OP said if the wires are good just replace the magnet and that's what I did. Problem solved. I now always carry two sets of full brake assemblies with me as my brake problem occur hundreds of miles from home. I also carry wire. Never a good feeling being over the road with a problem. I hope that this helps you.
    Happy trails
    My P3 will not allow brakes to engage when I'm getting short/overload error. I assume this is to prevent excessive current from flowing through wiring????
    I've already tried the spinning of wheels and could not get the error to occur. Again, only occurs when going down the road.
  • Sounds like up and down when pulling causes the wire to ground out. Disconnect brake wire at first junction disconnect all the magnet's read wire to ground while shaking it to simulate moving. Then hook each magnet to direct from controller and check. A lot of trouble for sure - but do not put a price n safety.
  • have someone apply the brake and watch the display while you wiggle pull and push every bit of wire from the TV to the drums that you can reach
    Yes that is a lot of work but that will be my plan unless I can first find an obvious short. I had the trailer on the road yesterday and was prepared to start disconnecting each brake assembly with hopes of isolating the break assembly and/or associated wires that may be the issue. Unfortunate I was not getting the error with enough regularity to do this.
    Again, if I can't find anything obvious I will eventually go straight from each individual brake assembly to truck.
    That was the first thing I did on the first day of the problem. Hoped I could find an easy fix. No luck.
    Been busy last two days but next step is to pull wheels and check inside each brake drum, and then check wiring running through axle tubes.
    I really appreciate all the replies and suggestions. Thanks!!
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
