dman535
Sep 29, 2020Explorer
I started by cutting the power wire to the passenger side front axle, no change. Then cut the drivers side - an no more short. I reconnected the passenger side and have three drums running without issue. I can only assume at this point that the magnet in one axle is causing the problem.
Unless - just removing one wheel caused enough of a current drop not to trigger the overload.
