BobsYourUncle's avatar
Jul 23, 2019
Trailer brakes weak, a few questions:
32 foot TT, about 7000 pounds plus our gear and stuff:
I've noticed the brakes are underperforming substantially. Got the gain on the Prodigy turned all the way up, when I grab the lever and throw max voltage at the brakes, all it does is slow the thing down a little. I'd say maybe 20 percent efficiency at best.
Not good enough, time to open it up.
I've been wrenching my own vehicles since I was a teenager, I rebuild engines, trannies and every other aspect of cars and pickups, therefore I know what I'm doing with mechanical things.
I've been doing brake jobs all my driving life.
However, I have never had trailer brakes apart.
I'm wondering, do most trailers have a similar adjustment technique as the old drum brakes on the old 60s and 70s cars? Where you pull off the little rubber cap on the backing plate and get in there with a brake tool or bent screwdriver?
Weak brakes, could they just be suffering from bad need of adjusting?
Are they self adjusting like the old cars or do we have to get after them once in a while?
Just thought of this now, but suppose I should get under there, probe the wires and make sure I have voltage at the hubs....
Should be able to lock the wheels up with full on braking. Not so here...
Tips and tricks for getting my brakes in order? Best method to check each wheel?
Guess I should pull the drums and have a peek anyways.
Long trip coming up soon, gotta take care of this before departure.
TT is 12 years old, maybe it needs shoes.
