DFord
Jul 25, 2019Explorer
3 AMPS PER MAGNET should be able to lock the drum. That would be the maximum current draw per brake. Usually much less than that but if you're magnets are drawing anywhere near that much power and the brakes aren't working correctly, it's not a wiring issue. It would be time to pull a drum and see what's going on inside.
