As per another thread, I have yet to change out the 7 pin cable. Prior to doing so, I decided to confirm whether the old cable is still usable. I hooked up the 7 pin to the truck (which recogniz...
sitting still, the Brake pedal will NOT activate the brakes. But, the manual lever will. Start the truck, use the manual brake lever/button and attempt to pull forward. After less than a foot the brakes on trailer should lock up and stop you. Trailer brakes operate on dc voltage. 12 volts to the brakes is FULL lock up brakes. 1 volt thru 11 volts will activate in increments. Doug
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
