As per another thread, I have yet to change out the 7 pin cable. Prior to doing so, I decided to confirm whether the old cable is still usable. I hooked up the 7 pin to the truck (which recogniz...
Something else to check.....You can get 12v at the magnets with just a couple of strands of the brake wire. However it take the whole stranded wire to get proper amps to the brakes. When buying new or a used rv/work trailer I always run a amp check at the magnets. I've found those clam shell wire connectors over a short time can loose enough connection to limit amps to the brake....but still get 12v.
