marpel
May 28, 2022Explorer
Trailer Brakes
As per another thread, I have yet to change out the 7 pin cable. Prior to doing so, I decided to confirm whether the old cable is still usable. I hooked up the 7 pin to the truck (which recogniz...
marpel wrote:
Resurrecting this thread.
As I have been tied up looking after my grand-daughter, have been unable to work on the trailer until today. With old 7 pin cable and new one which I replaced today, the lights etc work, but none of the brakes operate (tandem axle).
I hooked up a brand new battery and pulled the breakaway switch. The brakes did not activate at any wheel.
I have checked the wiring at the front of the trailer and was only able to go under the trailer and do a visual on the brake wiring to all wheels, and everything looked OK (I know this is not definitive).
So, if the brakes are wired in parallel, which it appears they are, and if all brakes are inoperative, does this mean the issue is in the main cable somewhere prior to the first wheel connection? Just trying to get some advice on exactly where I should concentrate on looking.
Unfortunately, I am still doing babysitting duties so my time is limited to work on this. And the best part,I only have until this next weekend to figure this out.
Thanks in advance for any help,
Marv
